Superchips FlashPaq options questions
Old Jan 27, 2006 | 04:20 PM
rcassettyjr's Avatar
rcassettyjr
Default Superchips FlashPaq options questions
I have an 04 Hemi 2wd Shortbed. I have the new Superchips FlashPaq and I am pleased with the performance increase. I am wondering where anyone else with this setup has set thier rev limiter? I set mine for 6000 and under normal driveing it is fine but at WOT there is a huge lag when it shifts from 1-2 and from 2-3. It is Ok in the other gears. Is this normal? It didn't do this before I changed the rev limiter. I may just set it back to normal but I just wanted to know.
Thanks
Bob
Old Jan 27, 2006 | 04:27 PM
5point7 hemi's Avatar
5point7 hemi
Default RE: Superchips FlashPaq options questions
I messed around with mine when I first got it, I had everything maxed out and had the same issue, it was not shifting the way I wanted it to.
So, what I did was keep bringing the rev limiter down by 100 rpm's then doing high speed runs until It shifted to my liking.
I think it ended up being 6150 or so.
Thats the cool thing about the tuners, you can set it the way you like it.
Old Jan 28, 2006 | 04:01 PM
2005 DAYTONA's Avatar
2005 DAYTONA
I set mine at 6180, and it shifts fine, WOT whines out with no LAG or dead spots. reg driving also same thing ferm shift points and longer shifts. I like this setting.
