4.7 horsepower increase
Old Jan 28, 2006 | 10:18 PM
rrunner69's Avatar
rrunner69
Default 4.7 horsepower increase
Hey guys i am a newbie here but not to mopars so here's something i could use some help with, looking to get some more power out of my 04 ram without doing any major engine work,cam, heads, ect.....the 4.7 is a little under powered i think i may be getting spoiled by driving muscle cars mabey the ram is were it's supposed to be but i need a little more. Please help me out thanks
Old Jan 28, 2006 | 10:34 PM
AIR RAM's Avatar
AIR RAM
Default RE: 4.7 horsepower increase
ORIGINAL: rrunner69
Get yourself a set of 4.56's and a programer... then go with an aftermarket Muffler with a performance "Y" Pipe and an electric cutout. After that you should look into an electric fan and ASP underdrive pulley. Also the FAST MAN throttle body is a great mod as well. When your ready to make REAL power then upgrade to the FAST MAN 206 cams... this will be a BIG increase in performance and you will be more than happy with the outcome... if you do all the mods listed about a quad cab 4.7L running mid 9.5's in the 1/8 ... this is SINGLE CAB HEMI teritory. MOST Quad Cab HEMI's are running low 10.0x in the 1/8 mile.
SPEED SAFE, AIR RAM
Old Jan 28, 2006 | 10:37 PM
rrunner69's Avatar
rrunner69
got a link were to get this stuff?
Old Jan 29, 2006 | 02:27 AM
kvsmith2004's Avatar
kvsmith2004
Is there a programer for the 4.7?
Old Jan 29, 2006 | 04:29 AM
stykthyn's Avatar
stykthyn
There isn't a programmer for the 04's yet I dont believe. Jet Chips makes a chip, but I havnt heard very many good things about it( worst being that the PCM resets to stock every couple of months). Get a CAI and exhaust, but stay away from the cutouts. The 4.7 needs the backpressure. You open those up and you can feel all the ponies slipping out of your tailpipe.
I am like you rrunner69, I have an LS1 camaro that runs 10's in the 1/4 all day. After that my truck just isnt as exciting.
Old Jan 29, 2006 | 12:31 PM
justint420's Avatar
justint420
Is there a programmer for the 2003 4.7? Thanks
Old Jan 29, 2006 | 02:03 PM
AIR RAM's Avatar
AIR RAM
NO engine likes "BACK PRESSURE" not one engine on earth likes it! BUT they do like HIGH VELOCITY and you can change the velocity by changing the volume of the system (ID OF PIPES) or the amount of air you flow through it (455ci vs. 348ci). If you flow less air (348ci or even our belovid 287ci) then you need less volume to keep the VELOCITY high. If flow more air then you need a larger system to again handle more volume... The goal is to keep the velocity high without creating "BACK PRESSURE"... If you go too large you LOSE velocity... If you go too small you gain back pressure....
SPEED SAFE, AIR RAM
Old Jan 29, 2006 | 02:04 PM
AIR RAM's Avatar
AIR RAM
ORIGINAL: justint420
YES... contact DAN at FAST MAN and he can hook you up with a custom flash from BG... Or you can go witht he SUPERCHIPS program which is also a great mod... not as much power as the CUSTOM flash but you have the control to remove it and reinstall it at will.
SPEED SAFE, AIR RAM
