Anyone ever heard of this "Scangauge"?
Have any of you seen or heard of this?
http://www.scangauge.com/
It just looks kida like a good tool to have...
SPEED SAFE, AIR RAM
SPEED SAFE, AIR RAM
never heard of it, but it can't be to accurate if it think an srt is getting 15mpg
j/p. i don[t see a use for it seems like everything the overhead tells you anyhow.
I have one. I had a 2005 F150 that I put it in. Only down side with the unit is that it 'scans' your computer for the information to display every 2 seconds. So if you have one of the read outs set on RPM its not a fluid constant reading. You can tell the unit to 'fast scan' and that cuts it down to like every one second, still choppy for the RPM.
I put it in my 2006 RAM and it all works good but I get no MPG reading! I don't know if its because I have an over head computer that shows that or what...
I think you can put in custom scan jobs. I think ya get info from the company for the codes and it will show stuff that it couldn't from the factory.
Also there is a problem showing data on the HEMI with the multi displacement. I have the standard HEMI but the site says there is some problems.
One thing I like it showing the amount of power you motor is makeing! It shows it in % so like if your at %60 you still have a lot more power left in your motor. Usualy by the time you get to %90 the trany will shift down if its an auto. I have goten my F150 with the V6 to %99, but not my HEMI...
