Trouble codes
Old Feb 14, 2006 | 02:27 AM
Redhawk996's Avatar
Redhawk996
Default Trouble codes
For the Dodge mechanics out there...What is a 1491 or P01491 code? My "Check Engine" light came on yesterday and had a buddy check it out on his scanner. Unfortunately, his book only goes up to 999. I don't notice any change in the way it runs or any odd sounds.
Thanks,
Mike
Old Feb 14, 2006 | 03:03 AM
silverburst's Avatar
silverburst
Default RE: Trouble codes
Im no mechanic, but from what I found check your 25 amp radiator fan fuse.
It seems to be a radiator fan problem, and judging by google, is fairly common (enough to fill the first page of results) on 2002 1500 rams.
Old Feb 14, 2006 | 10:19 AM
kenihemi's Avatar
kenihemi
Yup,
P1491 Chrysler Radiator fan relay control circuit
Old Feb 14, 2006 | 02:30 PM
Redhawk996's Avatar
Redhawk996
Thanks for the posts!
I looked into it a little more and found out that it is an A/C Condenser Fan Problem. I looked at the fuses and the #39 A/C Condenser Fan fuse is blown. I put another fuse in and hit the A/C and it blows again. So, I unplug the fan put in another fuse, hit the A/C and it is ok. As soon as I plug in the fan, it blows. The fan free-wheels but it still could be a short in the fan itself. Price of the fan..$47 from dealer. They also said I would need the shroud and wiring for $135 and $9.25 respectively. I'm not sure why I would need the shroud and wiring
Did you know on a newer generation Ram...
Turn on the key 3 times (without starting) that the digital odometer will kick out the error code
With the key on...
Hold the trip meter button for 3 seconds, the engine hours is displayed
I thought that it was kinda cool..
Thanks for the help,
Mike
Old Feb 14, 2006 | 03:10 PM
silverburst
No problem.
Im near long beach as well, What dealer are you taking it to?
I havent had mine that long, do you have a local dealer you trust around here?
Old Feb 17, 2006 | 01:45 AM
Redhawk996's Avatar
Redhawk996
I take mine to Glenn E. Thomas on Cherry Av. and Spring St. They're a reputable dealer that has been in the area for a coupla hundred years or so...;0)
