Cigarette Lighter Removal
Old Feb 16, 2006 | 10:26 PM
reindeerman's Avatar
reindeerman
Default Cigarette Lighter Removal
I am trying to remove the cigarette lighter from the center dash panel on my 02 1500. I need to be able to reinstall when I’m finished. Does anyone know the trick to disengage the lighter socket from the panel without breaking anything?
Old Feb 17, 2006 | 12:55 AM
BlueHemi's Avatar
BlueHemi
Default RE: Cigarette Lighter Removal
Once you remove the center dash panel you should be able to unscrew the rear lighter casing from the piece that goes through the panel from the front. Take a look at a replacement lighter at any auto parts store.
Old Feb 17, 2006 | 01:45 AM
reindeerman
Blue Hemi, That’s what I thought too until I had the panel off. Nothing like the generic replacement type. This is OEM stuff and a different. Looks to snap and click in place with no way to release without breaking.
Anyone encountered this?
Old Feb 17, 2006 | 02:04 AM
BlueHemi's Avatar
BlueHemi
I should've known it wouldn't be that easy. I just looked at my manual and it didn't say anything about how to get it out. Sorry I couldn't help!
Old May 26, 2018 | 11:58 AM
BonzoHutch's Avatar
BonzoHutch
I got the panel off and looked the wiring over. It all looks OK. Both of the outlets are giving the spike to the phone charger. I checked the output voltage and it is steady at a little over 14 volts. The amperage is a little under one amp I think on both outlets. Output did not fluctuate on the meter but it is not super sensitive like the phone. I was wondering if the voltage regulator took a hit when It slammed the pot hole. Would that cause this kind of issue?
Old May 27, 2018 | 08:55 AM
You have an active thread going already. No need to resurrect a 12 year old thread to ask the exact same question.
