Custom Sub Enclosure
Old Feb 28, 2006 | 12:50 PM
otnielarencibia's Avatar
otnielarencibia
Default RE: Custom Sub Enclosure
doesn't make much sense...sorry
Old Feb 28, 2006 | 12:53 PM
Hunt_The_Dragon2000's Avatar
Hunt_The_Dragon2000
ok imagine the top of the box........imagine having two pieces of wood cut out to that shape........now the lower piece u cut the middle out just leaving like 2 inches enough for the top piece to mount to......
Old Feb 28, 2006 | 01:04 PM
otnielarencibia
oh ok i understand now. But the speakers are mounted on the top one right? And how is the amp in the bed?
Old Feb 28, 2006 | 01:10 PM
Hunt_The_Dragon2000
also on the bottom piece there bare 2 circular cut outs that the subs mount to. before the box was covered it looked alot like the mtx box. look at that and youll get the idea. amp and cap are mounted in the bed of the truck. Fibergalss topp. wires running between cab and bed.
Old Feb 28, 2006 | 01:32 PM
otnielarencibia
does any air leak through the front or back?
Old Feb 28, 2006 | 01:36 PM
Hunt_The_Dragon2000
very air tight. wood is fiberglassed to the bottom. cannot be removed
Old Feb 28, 2006 | 01:48 PM
otnielarencibia
Is it fiberglassed all around inside?
But on the two pieces that screws onto the existing 2" outline they don't leak air? Sorry to bother
Old Feb 28, 2006 | 02:14 PM
Hunt_The_Dragon2000
inside is fiberglass also, the two wood pieces had a layer of sealent in between them before screwed together, there is no removable pieces on this box. air tight
Old Feb 28, 2006 | 02:25 PM
otnielarencibia
so you put sealant between the two pieces and the 2" outlining too?
BTW what kind of sealant?
Old Feb 28, 2006 | 02:44 PM
Hunt_The_Dragon2000
yes it was a fiberglass apoxy
