Radar Detector wiring
Old Mar 1, 2006 | 10:40 PM
laythg's Avatar
laythg
Default Radar Detector wiring
Hi all,
I have to believe this has been asked 1000 times. But I promise I did a search and couldn't find anything.
I have a 2005 SLT with overhead console. Wondering which color wire in the overhead harness is keyed power and which one is ground. Looking to tap them for a hard wired radar detector.
Also, any secrets to removing the console from the headliner to access the harness?
Thanks in advance!
Layth
Old Mar 1, 2006 | 11:32 PM
JoeKramer's Avatar
JoeKramer
Default RE: Radar Detector wiring
I don't know what wire would do it. But you should be able to just use a volt meter on them to find a +12. If you turn the key off and there is no power then you have your hot lead!
For ground its usualy a black wire. Take the volt meter and check for little to no resistance to chassy ground (with key off) on the black wire and you should be ready to go!
Old Mar 2, 2006 | 12:34 AM
GA Hemi's Avatar
GA Hemi
I have an '05 SLT Hemi QC in which I installed a radar detector. I bought a radar detector power cord from Radio Shack and cut the end off and extended the wire to the fuse panel under the hood. A lot of work I know but what I wanted to mention is how I got the wire from the roof to the radar detector. I removed the piece of plastic that holds the sun visor near the overhead center console and drilled a hole in it just large enough to allow the wire to go through. It made a very neat and clean install. If anyone would like to see it, let me know and I will try to post a pic.
Old Mar 2, 2006 | 12:56 AM
GA Hemi's Avatar
GA Hemi
Decided to try and post a pic of my radar install... hope it might help someone...
[IMG]local://upfiles/22142/24F4D891A0274BFD9B879D82EE04AC00.jpg[/IMG]
Old Mar 2, 2006 | 03:40 AM
HuskyJazz's Avatar
HuskyJazz
That looks pretty good. Never really thought about hard wiring my detector, but I just mught have to after seeing that.
Old Mar 2, 2006 | 09:29 PM
JoeKramer's Avatar
JoeKramer
That does look good... Any problems with the suckers comming off the glass? I go off road from time to time and will problably need a perminent mount for mine when I do it.
Old Mar 2, 2006 | 10:45 PM
AntRock's Avatar
AntRock
i have my radar detector mounted on the rear view mirror (hanging), i plan on hardwiring it to the rearview harness for the auto dim. the bracket was custom made from a guy on a 350z forum. it has not falling off yet not even after this!
[IMG]local://upfiles/24181/0379575D17664607977FCC13720B91E6.jpg[/IMG]
[IMG]local://upfiles/24181/FC998BCC7969467EABEF809B443A9BF8.jpg[/IMG]
[IMG]local://upfiles/24181/D88322ADCA434CC0B99EFE853E2574A7.jpg[/IMG]
