Track Time
Old Mar 2, 2006 | 12:14 PM
cupcake's Avatar
cupcake
Default Track Time
Last night I took the truck to the track for the first time. I went expecting 14.5's. My mods are in my sig. I was unfortuniete enough to only make 2 passes. The first I went 14.9 and the second was 14.7. I Think 14.2 is reachable only b/c I wasn't launching the truck properly, the first pass I held the brake and kept it about 1k rpm got cought sleeping on the light and ran a 14.9 the 2nd pass I held the brake @ about 1700rpm still no wheelspin got a 14.7 I also think if i use tow haul and adjust the shift points a bit Higher I can keep it in 3 gears instead of hitting 4th right before the end where it shifts and bogs just a tad. Also should be getting a tonneau cover which should help out, hopefulyl then I can see a 13.9. Ill post time slips later on.
Old Mar 2, 2006 | 12:21 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Default RE: Track Time
Good times! I'm going to OSW March 10th...I'm hoping for 14.5's also.
Old Mar 3, 2006 | 03:27 AM
silvernightmare's Avatar
silvernightmare
good luck with your times.
