2004 recalls for Ram 1500
Old Mar 4, 2006 | 01:53 AM
jastweed's Avatar
jastweed
Default 2004 recalls for Ram 1500
Make : DODGE Model : RAM 1500 Year : 2004
Manufacturer : DAIMLERCHRYSLER CORPORATION
NHTSA CAMPAIGN ID Number : 03V503000 Mfg's Report Date : DEC 03, 2003
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Potential Number Of Units Affected : 514
Summary:
ON CERTAIN PICKUP TRUCKS, THE TRANSFER CASE TO TRANSMISSION ATTACHING FASTENERS MAY NOT BE TIGHTENED CORRECTLY. THIS COULD CAUSE THE TRANSMISSION ADAPTER OR TRANSFER CASE HOUSING TO CRACK AND LEAK FLUID.
Consequence:
CONTINUED OPERATION CAN RESULT IN PROPELLER SHAFT SEPARATION AND DAMAGE TO FUEL SYSTEM COMPONENTS, WHICH COULD LEAD TO A FUEL LEAK. FLUID AND/OR FUEL LEAKAGE IN THE PRESENCE OF AN IGNITION SOURCE CAN CAUSE AN UNDERBODY FIRE.
Remedy:
DEALERS WILL RETIGHTEN THE TRANSFER CASE TO TRANSMISSION FASTENERS. OWNER NOTIFICATION BEGAN ON DECEMBER 22, 2003. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-992-1997.
Notes:
DAIMLERCHRYSLER RECALL NO. C39. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONÂ’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Check to Request Research. Submit below.
NHTSA CAMPAIGN ID Number : 04V221000 Mfg's Report Date : MAY 04, 2004
Component: EQUIPMENT:OTHER:LABELS
Potential Number Of Units Affected : 6183
Summary:
THE VEHICLE CERTIFICATION LABEL ON SOME PICKUP TRUCKS LISTS INCORRECT TIRE, WHEEL, AND RECOMMENDED INFLATION PRESSURE INFORMATION WHICH DOES NOT CONFORM TO THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 120, 'TIRE SELECTION AND RIMS FOR VEHICLES OTHER THAN PASSENGER CARS.'
Consequence:
INSTALLING THE INCORRECT TIRE/RIM SIZES AND LOADING THE VEHICLE TO THE WEIGHTS SHOWN ON THE LABEL CAN CAUSE TIRE FAILURE AND RESULT IN A CRASH WITHOUT WARNING.
Remedy:
OWNERS WILL BE PROVIDED WITH VEHICLE CERTIFICATION LABEL OVERLAYS CONTAINING THE CORRECTED INFORMATION RELATIVE TO VEHICLE TIRE AND RIM SIZE, AND RECOMMENDED INFLATION PRESSURE. THIS RECALL BEGAN ON MAY 5, 2004. OWNERS SHOULD CONTACT DAIMLERCHRYSLER AT 1-800-853-1403.
Notes:
DAIMLERCHRYSLER RECALL NO. D24. CUSTOMERS CAN ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATIONÂ’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
Old Mar 5, 2006 | 03:09 AM
sandiegohemi's Avatar
sandiegohemi
Default RE: 2004 recalls for Ram 1500
Compare these two recalls to the ones from Toyota, Chevrolet, Ford, and Nissan. Big difference!
