Abs and odometer. Fan
Old Mar 21, 2006 | 10:50 PM
rmvm2002's Avatar
rmvm2002
Default Abs and odometer. Fan
Not much lack with our 2004 2500 ram diesel. Earlier I have done some repairs on the power steering. Now ABS failed, but I hope to have it repaired. I found somebody on ebay that actually repairs (not replaces) the module for much less then replacement.
However, after I removed the ABS controller my odometer and speedometer stopped working. Is it all connected?
Then I also have a problem with the inside fan (AC and heat); which seems to be occasionally running with the ignition key out. Perfect way to run the batteries empty. Any input on what to do?
At 46K that’s a lot of failures and money.
