ATF+4 mixed w/power steering fluid in ps reservior?
Old Mar 24, 2006 | 12:18 PM
jrsick's Avatar
jrsick
Default ATF+4 mixed w/power steering fluid in ps reservior?
Is ATF+4 compatible with regular power steering fluid? I topped off my ps reservoir with standard ps fluid then discovered that my truck uses ATF+4. Should I drain and start all over?
Old Mar 24, 2006 | 12:46 PM
osteodoc08's Avatar
osteodoc08
Default RE: ATF+4 mixed w/power steering fluid in ps reservior?
The real question is why the PS fluid was low in the first place. Is it leaking somewhere?
As far as compatibility, I'm not sure. You can always flush the system with fresh ATF+4 to be on the safe side.
Old Mar 24, 2006 | 01:23 PM
rob[GL]'s Avatar
rob[GL]
Power steering leaks have been a huge problem on the 3rd gen rams... Or so the service writer at my dealership told me...
I just had to have my hoses and the resovoir replaced under warranty a few weeks ago...
Old Mar 24, 2006 | 01:27 PM
greenmachine's Avatar
greenmachine
I do know that you could always put trans fluid in power steering but never power steering fluid in the trans. So I would have to say you will be alright unless you take it in for warranty work.
Old Mar 24, 2006 | 01:28 PM
06REDRAM's Avatar
06REDRAM
AS FAR AS I KNOW ITS COMPATIABLE. SAME STUFF DIFFERENT BOTTLE
