cant find tow spec for 03 1500 2 wheel dr. w/HEMI
Can someone please tell me the tow specs for a 2003 1500 halfton 2 wheel drive quad cab with the hemi and 3.92 rear ratio?? Dealer is closed today so I coulnt find out. Am buying travel trailer that wieghs 7100 empty and need to know if I can pull it.
sonny,
Do you have 17's or 20's? If it weighs 7100# empty, make sure you add 500 - 1000# for water, personal items, etc. See if you can find out what the GVWR is for the trailer. That's the number you really need to go by.
maybe this will help http://dodgeram.info/2003/load-tow/1500.html
ORIGINAL: HuskyJazz
You should be fine. I just checked on Autotrader and 03 qc 2wd without the hemi will tow 8350. So you shouldn't have a problem.
