Floor Shifter
Old Apr 12, 2006 | 07:54 PM
WalterPPC's Avatar
WalterPPC
Default Floor Shifter
I have a 2005 Ram 1500 and was wondering if there was a kit or way I could make it a floor shifter.
Old Apr 22, 2006 | 01:09 PM
srenken's Avatar
srenken
Default RE: Floor Shifter
Why would you? The electronic shift functions the same way, but forces you to shift the way it was designed and instructed in the owners manual. Going from 4Lo to anywhere, you must be in neutral, or it will not shift, you also must be rolling between 2 to 5 mph. Going from anywhere to 4Lo it is the same way. This is the same way the t-case should be shifted on the manual shift-on-the-fly t-case, but people refuse to do it that way, ending up damaging the t-case in the process.
Old Apr 23, 2006 | 08:22 PM
WalterPPC's Avatar
WalterPPC
Its an automatic 2wd truck, I just like how it would look.
Old Apr 23, 2006 | 11:31 PM
HemiMan4451's Avatar
HemiMan4451
Are you saying just being able to go from drive to park and stuff on the floor, or do you want a manual tranny conversion?
