Brake Controller
Old Feb 14, 2007 | 01:16 AM
xjmark's Avatar
xjmark
Default RE: Brake Controller
My truck came with the same pigtail set. It's supplied from the factory as part of the towing package so that you can splice into your controller wiring. I was planning on using it until I found this premade wiring harness that plugs right into the truck and controller. http://www.rvwholesalers.com/catalog...productid=1949
For the twelve bucks that it costs, it wasn't even worth taking the soldering iron out of the tool box.
rvwholesalers.comhad the lowest price on the Prodigy that I found at the time, and got my stuff in two days.
Old May 27, 2007 | 12:35 AM
boatman's Avatar
boatman
Where is the plug under the dask for the harness?
Old May 28, 2007 | 06:38 PM
Worldtravelers5's Avatar
Worldtravelers5
On the left side of the brake pedal, tucked up under the dash.
Here's a link to a photo of my '05 1500 connector: http://picasaweb.google.com/worldtra...mWiringHarness
For what it's worth, I've got a Primus controllor mounted on the left of the steering column (and no, I never hit my knees getting in/out.
Old Feb 23, 2008 | 03:38 AM
phlytyer's Avatar
phlytyer
XJMARK: [sm=goodidea.gif]VERY clean install. Suspect this will be my solution. Thanks for the great post and pics.
Old Feb 26, 2008 | 11:35 PM
phlytyer's Avatar
phlytyer
XJMARK:
Is that just pressure fit, no bracket and if so any problems with shaking loose?
Old Feb 27, 2008 | 01:31 AM
xjmark's Avatar
xjmark
Thanks for the compliment phlytyer.
That's correct. It's just a pressure fit.
I used a thin piece of cardboard as a shim under the pad to help lock it in place.
It's stayed in place perfectly since I put it in. Even with a few panic stops where I had to jam on the brake lever, it didn't move a bit.
Old Feb 28, 2008 | 08:53 PM
phlytyer's Avatar
phlytyer
[sm=smiley20.gif]Should be a bit of routing and wiring this weekend.
