What to torque the rim at
Old Apr 27, 2006 | 12:14 AM
ultima4700's Avatar
ultima4700
Default What to torque the rim at
Just installed new Bilstein HD Shocks all around any one know what to torque the rim at I have the 17” OEM rims on my 03 1500
Old Apr 27, 2006 | 01:26 AM
tenntech's Avatar
tenntech
Default RE: What to torque the rim at
95 ft.lbs.
Old Apr 27, 2006 | 01:45 AM
reiderr's Avatar
reiderr
I've seen conflicting specifications between the owner's manual and the service manual. Some references specify 95 ft lbs. Other places specificy 135 ft lbs. I routinely torgue to 140 ft lbs using a torque stick on an air driven impact wrench on my 2005 1500 QC w/20s in the summer and 17s in the winter. BTW, 2500 and 3500 are 135 ft lbs consistently between the driver's manual and service manual.
Roger...
Old Apr 27, 2006 | 03:31 PM
osteodoc08's Avatar
osteodoc08
Use the 95 ft/lbs. The higher 135 ft/lbs is the old recommendation.....until they started getting even more warped rotors. I do it in 2 stages. Once at 50 ft/lbs and the other at 95 ft/lbs. That is what I did when I rotated the tires.
Old Apr 27, 2006 | 08:21 PM
BigRigTruckin66's Avatar
BigRigTruckin66
I use 100ft/lbs of torque. Use 95ft/lbs for the sebring.
Old Apr 27, 2006 | 10:39 PM
ultima4700's Avatar
ultima4700
Thanks
Old Apr 29, 2006 | 05:27 PM
srenken's Avatar
srenken
The spec is 130 +/-20 ft*lbs. Warped rotors was from them overheating, not from lug nut torque.
