Trouble finding body part
I have an 03 Ram QC SLT with the full package. 20 in rims, front air dam, ground effects, etc... I am trying to put dual flomasters on it and if any of you have the same type of truck you will know what i mean when i say that i cant find a piece to match the drivers side. the passenger side has a custom moulding where the tip exits and i cant find one to match the other side. any help would be great
Just to clarify a bit. the ground effects run all the way past my rear tires on each side. and the piece is the short one behind that tire. i dont want to leave a gap there by running duals out the rear.
i dont know how much help my post will be but ill give you an answer. if im reading your post right, you have the factory ground effects kit with the groove on the passenger side for the exhaust. you want to run a dual exhaust and are looking or some sort of rear skirt to match the has a groove on each side. i havent seen a replica of the rear skirt with a groove on each side. it may just be easier to take your truck to a body shop and have them make a groove on the driver side for you.
I had the same problem and found none, The Shop were i got my flows at did the hole for me
Driver cut side
https://dodgeforum.com/upfiles/22875...q494688880.jpg
Passenger stock side
https://dodgeforum.com/upfiles/22875...j244145184.jpg
not perfect but still hard to tell the diff.
Driver cut side
