FIXED > 06 Ram - Sirius Satellite problem after amp install
I should have tried this first, but I didn't. I disconnected the power from the battery and waited a few seconds and reconnected. I then started the truck and began testing. At first I only got channel 184, which is the demo channel (thinking I really broke it now). After a few seconds I got all the other channels and some of my other presets came back. All is back to normal.
Hey guys, hope you can help:
I have the factory radio w/ built-in Sirius tuner in my 06 Ram. I just had an audio shop install a High-Low converter, to split off my factory speakers into RCA, so I can hook up an Amp. They also wired a "remote on" for the amp. Everything seems to be working fine except for the Sirius. All my preset radio stations are still there and the CD and radio work as they always have.
Here is the whats going on:
[ul][*] All my Sirius presets went away (even though my radio presets stayed)[*] I can only tune in stations 1, 106-184[*] Stations 2-105 do not show a number (display is blank) and it keeps that same audio that would be station 1[*] I can set the station memory for Sirius stations, as long as it is a station I can actually get to
[/ul]
So, I have no idea what could make it partially work. This seems like something that would be an all or nothing situation. Anyone have any ideas. Is there maybe something I have to do to reset the system. I am concerned about messing with it, because I don't want to enable some security feature, which make make the situation worse. The audio shop said they'd look at it, but I don't know if they'll figure it out. ....Help?
[/ul]
