Headlight problem
Old Nov 19, 2003 | 01:05 AM
1badram's Avatar
1badram
Default Headlight problem
<FONT size=2>Hey everyone,</FONT></P>
<FONT size=2>I'm having trouble with my headlights. Whenever I hit the highbeams and then go back to the low the low don't come on right away. I have to "jiggle" the handle to make them come back on. I have also been driving and had the lights blink on and off. Any ideas what I should check?</FONT></P>
Old Nov 19, 2003 | 01:49 PM
Dodgegirl19's Avatar
Dodgegirl19
Lady Administrator
Try the Multifunction switch... it runs about $64.60... OUCH!!
~Amanda</P><edited><editID>Dodgegirl19</editID><editDate>37944.4518402778</editDate></edited>
Old Jan 3, 2004 | 07:00 PM
Redhairedcwgirl's Avatar
Redhairedcwgirl
<FONT color=#0000cc>Are you still having that problem? If so, and have not replaced the multi-function switch yet, try disconnecting the battery cables, loosening the trim around your steering column, ( be very careful -airbag) and spray some electrical contact cleaner in and around your switch (blinker, high beam, etc. switch). Let dry for a few hours, and put everything back together. I did this on my '99, was having the same problem and have not had any trouble since.May be especially dirty if you live ina dusty area or like to ride with the windows down!This may not fix the problem, but is worth a try opposed to a 60 dollar part. (No offense ,Dodgegirl19). </FONT></P>
Old Jan 7, 2004 | 05:52 PM
ramslt96's Avatar
ramslt96
<IMG src=smileys/smiley19.gif border="0">Something that you might not like. I have a 96 slt with 182000 miles. i love my truck and wouldn't trade it for the world, but it has the same problem. If you will take the panels off and look at the switch you will see that the wires have started to melt in two. i have replaced six of the multifunction switches since 97 and need another now. As it seems that everyone in my area cant drive there are plenty of wrecked dodges and i normally pay about $20.00 a switch at a junk yard. You may have to replace some of the wire, if you do be very careful to cut the wire right at the switch as there is not very much and you will need to splice more later. careful or you might go up in flames. Dodge will not acknowledgs this problem of wiring though they have always had problems with wiring. Good luck
Old Jan 27, 2004 | 11:04 PM
SoCA14's Avatar
SoCA14
Finally found a place whereI don't feel like a misfit. I have the same problem with my 96 slt. In addition, the dash lights on the odometer sometimes do not come on when I turn the headlights on. Is this the same type switch?
Old Jan 30, 2004 | 04:17 PM
ramslt96's Avatar
ramslt96
the dash lights on the odometer may be loose. have you checked them. It is really not a hard job to check just don't force the parts off, they will come off with a little tlc.
Old Jun 8, 2004 | 09:54 AM
BilgeRat's Avatar
BilgeRat
Default RE: Headlight problem
this is an old thread but seemed to be closest to the problem I'm having.
I have a Ram 1500 Conversion Van - yr 2000.
My LoBeams won't come on at all. HiBeams work fine. I have jiggled the switch. I can't find a fuse for the headlights. Is there one? How is that circuit protected?
Also while checking each fuse I saw 2 black relays to the left of the fuse block area. The top one seemd very warm to the touch. I swapped them and the same position still got hot.
Thanks,
BilgeRat
Old Jun 8, 2004 | 10:27 AM
billyd12's Avatar
billyd12
i have no dashlights, all the gauges work fine, same w/ the headlights, i just have no dash lights so at night time i gotta turn on a light to see how fast im going...if i could fine a way to fix this, that would be awesome. then went out about 2 months ago.
Old Jun 8, 2004 | 11:51 AM
Mikeg1005's Avatar
Mikeg1005
You might have a problem with a fuse. On my dads old 98' Jeep which I almost got but thankfully I didn't, on night in Wisconsin, our entire dash, taillights, and our headlights, all didnt work. Only when you turn the turn signal on, then everything blinked, the dash,headlights,tail, everything turned on and off with the turn signals, When we finally got to a gas station, we found that a fuse had blown out. So maybe check your fuses, our problem was one under the hood. My .02 cents
Mike
Old Jun 19, 2004 | 12:02 AM
CodeThreeDJ's Avatar
CodeThreeDJ
My 01 Sport does the same thing, as well as my father's 94. Curiousity's sake, quite some time ago I receieved a recal notice for electrical components under the steering column. Anyone know if this could be related, or what that notice was actually for? I kinda lost the notice, and subsequently never got it taken care of like I should have.
