Lights acting funny on an 02 ram 1500 sport quad
Old May 21, 2006 | 01:06 PM
tsrperf's Avatar
tsrperf
Default Lights acting funny on an 02 ram 1500 sport quad
The bulbs are all good, and the fuses are too. What am I missing? Please help. With headlight switch off, normally the "driving lights" would be on. They are not. I turn on the headlight switch, the right side headlight comes on, the left does not. I switch on high beam and the reverse happens, the right goes out and the left comes on. Then there's the signal lights, none work up front, although the bulbs appear to be fine, and only the rear right works. and flashes. very fast. There are no codes coming up on the odometer when you flick the key 3 times it just says "done". there aren't any wires wore or broken that I coud find.
By the way does anyone else find it very awkward changing headlight bulbs on this truck? Yikes!
Old May 21, 2006 | 10:18 PM
Sgt. Macks Ram's Avatar
Sgt. Macks Ram
Default RE: Lights acting funny on an 02 ram 1500 sport quad
Well I haven't had any headlight problems, but I did have a problem with my right tail would keep blowing the bulb. I checked all the connections for corrosion and made sure I didn't have a wire grounding out but it was all good. So I broke down and took it the dealership, and all they did was hook it up to the odey or thats what we always called it, and in a matter of maybe 10 min. it has never done it again. Thats how they get ya.
