Plastic bed liner
Old May 26, 2006 | 12:01 AM
speeddemon145's Avatar
speeddemon145
Default Plastic bed liner
was wondering if i should take off this plastic bed liner came with my 2004 1500 the wene I bought it used last month. the siderail plasic covers are coming off on the back ends the tape they used is not holding them on in the back. it is a OEM liner also. looks like first owner bought it at the dealership I am guessing.
Old May 26, 2006 | 12:41 AM
HemiBuell's Avatar
HemiBuell
Default RE: Plastic bed liner
Are you typing drunk or did you just drop out of the 4th grade?
Old May 26, 2006 | 02:06 AM
speeddemon145
Oh well
Old May 26, 2006 | 02:11 AM
speeddemon145
should Have known would get a smart *** reply. as always on these forums, a waste of time even writing .
Old May 26, 2006 | 03:21 AM
BgBluRam's Avatar
BgBluRam
Seriously.. The Plastic bed liners are cheap and easy. If a used truck has a scratched up bed liner the dealer spends a few bucks and installs a plastic bed liner to make the bed presentable. I would remove it and save for a Rhino Liner.. They are hands down the best.
Old May 26, 2006 | 06:15 AM
MR YOON's Avatar
MR YOON
take it off and get a spray in..
Old May 26, 2006 | 10:56 AM
osteodoc08's Avatar
osteodoc08
If you can afford it, a spray in is the best route. If you are short on cash, perhaps a Herculiner or something similar and then you can get rid of the plastic bedliner.
Old May 26, 2006 | 12:14 PM
speeddemon145
just removed it and the paint is worn to the primer on some of the bed ridges. was a lot of dusty dirt coating everything under it as well no rust yet as that is a good thing. anyone want a plastic liner? will try to get rid of it as i will not be putting it back in as if in less then 2 year it damaged the paint this much in a yaer or to more would have worn to the metal.
Thanks for all the help will get a spray on line that will hide all that worn paint.
Old May 26, 2006 | 02:32 PM
BadStratRT's Avatar
BadStratRT
The Forum Tyrant
im also a big fan of the spray on bedliners, as they cant "pull up"...that sucks about the paint being worn through...
Old May 26, 2006 | 06:54 PM
TheRedMonkey's Avatar
TheRedMonkey
I have a plastic dealer installed and its problem free. i am going to go with a spray in liner eventually but I won't go over the rail when I do for the cleanliness of the look of the truck. I will just get the plastic covers for when I do haul anything.
