Anyone reprogram horn 'BEEP' on the 06 key fob yet?
Old Jul 3, 2006 | 12:19 AM
New2Durango's Avatar
New2Durango
Default RE: Anyone reprogram horn 'BEEP' on the 06 key fob yet?
2nd thing is to put on the seatbelts. in the process of trying it now.
Old Jul 3, 2006 | 12:31 AM
silentblinder9502's Avatar
silentblinder9502
Well, I seen no reason to put seatbelt on being that it will not chime unless the truck is in motion without it being on. Since the key is only going to be turned to the "on" position and you will not be starting the truck, I skipped the seatbelt step and it worked fine.
Old Jul 3, 2006 | 12:40 AM
New2Durango
Doesn't work for me either.
Old Jul 3, 2006 | 05:00 AM
New2Durango
Says in the manual to put on the seat belt. Forgot why tho.
Old Jul 3, 2006 | 10:46 PM
mikahb's Avatar
mikahb
I figured the stupid thing out - had same damn problems y'all are having. The trick is NOT to read the manual, it will only lead you astray. However, DO read the ADDENDUM that comes with it - one of mine was specifically about disabling this. Here's a scan of the addendum, this oughta get it for ya.
2006 Ram Manual Addendum
Old Jul 7, 2006 | 07:55 AM
JRH_PowerWagon_06's Avatar
JRH_PowerWagon_06
The 2006 Power Wagon Manual is OK. No addendum needed.
I HATE the buttons on the Key/alarm. I keep setting it off
accidentally in my pocket.[:@]
Old Jul 8, 2006 | 10:51 AM
dcastine's Avatar
dcastine
MIKAHB - THANKS VERY MUCH!!!!
Old Jul 10, 2006 | 02:27 AM
Scootr's Avatar
Scootr
Yep,the addendum was the trick for my 06.
Old Jul 21, 2006 | 05:11 PM
mikahb's Avatar
mikahb
Good - glad that helped y'all out. I have disabled the panic button on all of my remotes - it's very simple. Take the fob apart, put a small piece of electrical tape over the contact for the Panic button, re-assemble. It's super-easy and 100% effective.
Old Aug 7, 2006 | 09:59 PM
derwood's Avatar
derwood
Thanks. Finally worked for me this time!
