warped rotors on mega cab
Old Jul 3, 2006 | 05:58 AM
i11m10c2's Avatar
i11m10c2
Default warped rotors on mega cab
man i think my rotors are warped up front ,brakes started squeeking last weeek and today coming home from mountains shimmy in steering and pedal pulse normaly id say ok and replace them but the truck has only 5600 miles on it, dont want to have to deal with dealer telling me brakes are not covered under waranty ,any advise??
thanks
Old Jul 3, 2006 | 11:08 AM
osteodoc08's Avatar
osteodoc08
Default RE: warped rotors on mega cab
I think that they are covered once if under 12K miles. It is a common problem with the Ram's. DC uses crappy rotors. Now would be the time to replace them because you'll either replace them now or replace them later. Take your pick.
Old Jul 3, 2006 | 12:09 PM
Silver Eagle's Avatar
Silver Eagle
Mine started out with deep groves on my right rear then my left rear. truck only had 1500 miles on it when it started took it bake to the deakler and they said it was nornmal wear. The I told them that I had a vibration in my steering wheel when I used my brakes. I made it up .The said my front rotors were warped 40 per cent and replaced them . After taking it back five times they finally decided to fix the rear rotors. At 5,000 .The parts manager told me that Chrysler uses Cheap rotors to keep the cost down.
Old Jul 3, 2006 | 05:10 PM
mazz's Avatar
mazz
My advice - Bite the bullet and replace those cheap factory rotors with some good quality aftermarket rotors and pads. Otherwise, you'll be going back to the dealer more often than you go do the dentist.
Old Jul 3, 2006 | 09:45 PM
alienyzf's Avatar
alienyzf
take the free rotors until you get irritated then buy whatever. Mine went out at 20k and I was SOL. I bought some drilled and slotted off ebay and some bendix pads from advanced auto. 1 month and no problems so far.
Old Jul 4, 2006 | 05:37 AM
i11m10c2's Avatar
i11m10c2
cool i will talk to dealer i will be down there for a recall for abs module so will se how goes and then decide
thanks for info
