What is a power wire?
Old Jul 10, 2006 | 12:32 PM
truckin151's Avatar
truckin151
Default What is a power wire?
What is a power wire and what does it do for your truck? Anyone?
Old Jul 10, 2006 | 02:28 PM
AIR RAM's Avatar
AIR RAM
Default RE: What is a power wire?
ORIGINAL: truckin151
Here is a quote from the website www.AIRRAM.com :
DODGE "POWER WIRE"
* Will work with any 3.7L, 4.7L, 5.7L & 5.9L with stock or aftermarket induction system* May also fit many other 2000 to present Dodge vehicles.
This =POWER=WIRE=> Is a PLUG & PLAY mod that will give you 8-10HP with less than 1 minute to install. The =POWER=WIRE=> appears to be the same as our "Air Temperature Sensor Re-Location Extension Harness" but the =P=W=> has a resistor solderd and heatshrunk in-line. It mounts in-line with your Air Temperature sensor and the harness as a piggy back. The Power Wire will trick your computer into thinking the air temperature is 20 degrees cooler than the actual temperature at "ALL TIMES". This causes your computer to adjust the timming and add at WOT it will add approximately 2% fuel, which is worth 8-10HP. So under a light foot you will only get the timing advance, because of this the Power Wire has been known to be worth 1MPG increase when driven lightly. On our G-Tech Pro Comp meter it showed almost a 10HP increase on a 2003 4.7L. This is an old trick that has been used for several years with the newer computer controled vehicles that use Air Temperture sensors to help control timming and Air/Fuel ratio... We havev just made this mod easyer and more reliable than ever... if you need to take it in for service, it takes just 10 seconds to return it back to stock with no evidence of this mod ever being installed!
This is a "PLAG & PLAY" MOD.... Many people have cut there harness too add a resistor... but why cut your brand New trucks Harness when you can get it all in one profesionaly made neatly soldered & heat shrunk and it will save you the time and trouble of cutting your own truck harness and possibly incorrectly installing it.... the work has been done for you! Just plug and Play!
SPEED SAFE, AIR RAM
