Transgo shift kits!!
Old Jul 11, 2006 | 11:21 PM
Memaxie's Avatar
Memaxie
Default Transgo shift kits!!
I am looking into getting a transgo shiftkit for my Ram 1500 4X4 2005. I already have a superchip in there right now. If I install the shift kit, will this affect my programming?
Old Jul 12, 2006 | 01:40 AM
05_black_beast's Avatar
05_black_beast
Default RE: Transgo shift kits!!
PN# SK45RFE is just a basic kit which will add some durability to some of the valve body components. It can prevent basic failures such as a broken retaining plate and broken accumulator springs. It'll also reduce the lock-up "clunk" some of these trannies have. It's just a basic kit you would use on a stock rebuild to give the customer a dependable rebuild. It's a kit that won't affect your shifting much at all and would be fine.
On the other hand, the new 45RFE-HD2 kit will give you a crisp performance shift. The only thing I would be concerned with is it having too quick of a shift and the trans going into failsafe. It's highly unlikely, but you may want to contact transgo and ask a tech if they have any info on using the performance kit with a programmer that cuts out the torque management on upshifts.
Old Jul 13, 2006 | 03:48 PM
MiniCwik's Avatar
MiniCwik
I have the 45RFE-HD2 kit installed and there is a portion of the kit that is supposed to be left out if you have a power programmer that makes modifications to the tranny in any way. For example the Superchips 3815 tuner does modify tranny line pressure to firm/change shift points.
I contacted Superchips about this since I have the 3715 tuner and this previous model does NOT make any modifications to the tranny line pressure, it only partially disables the Torque Management under WOT. So, I will be installing this resistor mod that will tell the tranny/PCM to increase line pressure in the tranny to firm up the shifts.
The kit is nice, it definitely helped make the shifts better/more predictable.
