Front end lift for 2WD
Old Jul 16, 2006 | 04:59 PM
wmichell227's Avatar
wmichell227
Default RE: Front end lift for 2WD
where'd you find it for that price? and has anyone done the install themselves? if so, any special tools required? how hard was it to do
I have done several sets of these for mine and friends jeeps. They are very easy but you should keep a few things in mind. First, you REALLY should get a set of spring compressors to pull the springs down enough to slip the doughnuts in. Also, you will need to detach the front sway bar before installing them. Thats about it..... The directions are pretty easy to follow. The spring compressors are the most helpful thing you gould get. I'm not sure which, but some auto parts stores will let you borrow them.
Old Jul 17, 2006 | 10:26 AM
tpowell3499's Avatar
tpowell3499
mine are daystr 1-1/2
