More power to the Hemi!!
Old Jul 18, 2006 | 08:06 PM
Memaxie's Avatar
Memaxie
Default More power to the Hemi!!
I am looking to get a few more HP'S under the hood of my 5.7 Hemi. I have already got a cold air intake, 8.5 Taylor racing wires and plugs, 40 super series flowmaster, and a superchip. Will headers make much more of a difference?
Old Jul 18, 2006 | 08:52 PM
Drew's Avatar
Drew
Default RE: More power to the Hemi!!
only on the middle to upper end of the RPM's. your low end torque will suffer a bit.
I put on a complete 2-1/2" aftermerket system on my little toyota, the low end did suffer, but above 2500rpm I can tell a big difference.
Old Jul 18, 2006 | 11:42 PM
Nicky B's Avatar
Nicky B
Yes headers will make a diference. And you should look into getting the 6.1L cam or if you want serious power get the KRC 218cam.
Old Jul 19, 2006 | 08:30 AM
HankL's Avatar
HankL
this interview of Dodge engineers who designed the 5.7 Hemi is worth a read:
http://www.motorage.com/motorage/art...on%20Injection
note the bit that says:
"The cast iron exhaust manifolds have also been carefully designed and flow-tested. The engineers report that at full-load on the dyno, these manifolds flow within 2.2 percent of a 4-into-2-into-1 exhaust header."
2.2% more than 345
is 352 hp
there is probably a bit more hp gain than this when the header is installed because it will lean the air to fuel ratio from the factory 11.8 more toward the best power level near 13.1 but remember that there is danger in this leaning...particularly to catalytic converters, exhaust valves and piston ring lands.
Old Jul 19, 2006 | 01:18 PM
truckin151's Avatar
truckin151
Adding headers will give you an extra gain in HP there is no doubt about that. You'll get a hell of a lot more than a 2.2% increase though by adding some high performance headers onto the configuration you have going for you right now. However this also depends on what type of exhaust you have on it right now. If I was you I would replace the entire exhaust system as well all at once. Keep your super 40s, but see if you cant get a decent cat-back system to attach it to and swap out your cat for a high flow cat and add/replace the "Y" pipe and you should notice a dramatic difference over what you have now. And it should sound alot meaner too if Im not mistaken..........
Old Jul 19, 2006 | 09:50 PM
abarmby's Avatar
abarmby
Go fot the 4:56 gears.
You get no HP increase but your MPG will get better and your truck will really get up and go !!!!!!
I've read a lot on this and am busily saving up right now. Best bang for your buck aparantly.
Al.
