35" tires on stock '05 powerwagon??
Old Aug 7, 2006 | 03:27 AM
cham79's Avatar
cham79
Default 35" tires on stock '05 powerwagon??
I've got a 2005 powerwagon that is stock. I want to upgrade to 35" tires on the stock wheels with no lift. I've heard that you can do this but also that the tires will rub pretty bad without a lift. I offroad with it so I don't want to loose any performance. Anybody out there have any info about this?
Old Aug 8, 2006 | 03:02 AM
redram5.9's Avatar
redram5.9
Default RE: 35" tires on stock '05 powerwagon??
35" tires can be done with no rubbing if you do a front end leveling. If you have a 1500 you can torque your torsion bars or if you have a 2500,3500 you can buy spring spacers.
Old Aug 8, 2006 | 04:45 AM
Monkeyman's Avatar
Monkeyman
I hate to hijack your thread but I have a similar question. I have an '03 1500 QC 4.7. I'd like to run 35s but I can't afford a suspension lift (and I think body lifts look bad). Is anyone running 35s on a truck similar to mine without a lift and with aftermarket rims? Does it rub anywhere??? I'm thinking it would clear the body but what about rubbing something at full lock???
Old Aug 8, 2006 | 12:34 PM
travie81's Avatar
travie81
You can do it without a lift. Your truck sits 2" higher than a stock 2500. I had 35's on my truck with stock rims, but now I went back to stock size due to fuel costs.
Old Aug 8, 2006 | 07:49 PM
redram5.9's Avatar
redram5.9
Crank your T-bars and you can fit 35" tires with no rubbing on a 1500 2002-2005.
