HEADERS Advice
Old Aug 16, 2006 | 04:10 AM
Hemi Lo's Avatar
Hemi Lo
Default HEADERS Advice
I want to put headers on my 06 Ram 1500 SLT 4x4. Advice from anyone? (Pros & Cons)
Old Aug 17, 2006 | 05:00 AM
ibanezta's Avatar
ibanezta
Default RE: HEADERS Advice
pros: headers are much better than the stock manifolds that are basically a pipe running across the exhaust ports. ive seen numbers like 30 hp, and 60 ft lbs from a header/y-pipe setup.
cons:do it yourself, you'll void the warranty. dodge will install mopar headers for you so you can maintane your warranty, however they will charge about 5k i hear for everything. not worth it at all in my opinion when a good set of headers is about 500-800.
http://rpmoutlet.com/ramhemi.htm thats a good go fast site. they have some headers on there. good luck.
