Aftermarket lights; recommendations like hella lights??
Old Aug 18, 2006 | 06:00 PM
boyd98's Avatar
boyd98
Default Aftermarket lights; recommendations like hella lights??
Just now thinking i need some aftermarket lights that sit behind the grill. I noticed some ppl have hella lights.
What models you recommend and how easy is the install; i'd like to thave some lights that i can switch on and off from the current cigarette lighter near the ash tray?
Any thoughts, what can i expect for costs?
TIA,
Boyd
Old Aug 19, 2006 | 12:24 AM
kvsmith2004's Avatar
kvsmith2004
Default RE: Aftermarket lights; recommendations like hella lights??
I got my Hella 500's for $70. I have them mounted behind my grill. As far as putting them in all you should need is about an hour or so, its not really to hard. The lights come with a wire harness, you will just need to drill two holes, then there is a plate in the firewall that is for a clutch, i think, I just drilled a hole through that. The lights also come with a rocker switch that I hooked up through the power outlet at the bottom of the dashboard so they always have power to them even when the truck is off. I will take some more pic's of where I went through the firewall and where the rocker switch is mounted. Here is one pic for now.
[IMG]local://upfiles/27663/6A86676B369E46BB9081C6DD5BEC02CB.jpg[/IMG]
Old Aug 19, 2006 | 02:29 AM
kvsmith2004
Oh yeah and one more thing. If you set up your aftermarket light independently like mine make sure that you remember to turn them off! I run mine during the day sometimes and I have made that mistake.
Old Aug 19, 2006 | 07:13 AM
20brewcity02's Avatar
20brewcity02
can you splice off the flog light power wire, or will that draw too much power?
Old Aug 19, 2006 | 07:54 PM
kvsmith2004
I don't have fog lights on my truck. The hella lights a 55 watts each, I don't know if that would draw to much power. I think if you upgraded the fuse for the fog lights it may be possible, but then again I don't know much.
Old Aug 19, 2006 | 09:45 PM
Gone Fishin's Avatar
Gone Fishin
You could easily "trigger" the new driving lights off the fog lamp relay, then wire in an idependent power line to the lights from the battery. The wiring harness you get should also have a relay with it for this. You could also trigger the relay "on" from a powered wire from the key switch, then when you turn off the key, the lights are off. Just don't run the power supply wire to the new lights from the power wire to the fogs. To much amperage draw, will definitely shorten the life of the bulbs, and bulbs won't run to full potential.
