gear?
Old Aug 22, 2006 | 01:03 AM
NYDODGE's Avatar
NYDODGE
Default gear?
i have a 06 dodge big horn edition which came with 20 and 3.92 gears i cruise at 70 mpph @ 2000 r 4.56 to much or 4.10 better. keep in mind i have 33 inch tire and have no plans to change them with the cst 4 inch lift just want a liitle more power since i am pushing more air under the truck and over the truck
Old Aug 22, 2006 | 03:26 AM
A10 WARRIOR's Avatar
A10 WARRIOR
Default RE: gear?
Are you asking which gears would be better?
If so, the 4.10s will make an improvement, but 4.56s will be much more noticible by far.
But for daily driving, I would probably stick with 4.10s since higher gears put unneeded wear and tear on the engine.
Are you doing this yourself or having a mechanic do it?
Old Aug 22, 2006 | 09:09 AM
DCXgageman's Avatar
DCXgageman
Default RE: gear?
My PW turns 2500rpm@75mph. It rarely goes back to 4th on the freeway unless I'm towing. Real happy with it, real easy to tow. Also, since break in and going to synthetic oil, I am getting 13-14 mpg, as compared to 11.7 (best) before the switch, not bad for a 6500+ # truck that is 6 1/2 feet in the air.
Also, 3.92 to 4.1 is less than a 5% change, you won't be impressed if you are unhappy with the current gears. 16% for 4.56 gears will increase to about 2300rpm@70mph, not a huge diff IMO.
Old Aug 22, 2006 | 11:27 AM
stump_breaker's Avatar
stump_breaker
Default RE: gear?
Honestly I would look at 5:13's. DO a search and get the formula for the rpm range.
Installing gears won't make your engine wear out sooner. trying to overwork it to turn those big, heavy wheels will though. I love my 4:56's and should have done it a year ago. I run the 17's though.
