Motor noise at start up
Old Aug 24, 2006 | 01:31 AM
gotitbad's Avatar
gotitbad
Default Motor noise at start up
I have a 03 RC with a HEMI. When I start it up after sitting a few hours it makes noise like all the lifters are loose????? Is this normal? I have had it less than a year and its 3/36 is up in Sept Please help
Old Aug 24, 2006 | 06:54 AM
abarmby's Avatar
abarmby
Default RE: Motor noise at start up
Silly question but...............have you checked the obvious, like the oil level?
If your low in capacity, your oil pressure might not be what it should be?
Al.
Old Aug 24, 2006 | 09:11 PM
speeddemon145's Avatar
speeddemon145
my 04 5.7 hemi with 36000 miles on it ticks some after sitting as well guess the oil takes a few seconds to get to the lifters is all and my oil level is full and presure is good as well.
Old Aug 25, 2006 | 12:55 AM
arrowman's Avatar
arrowman
Oil level?
Using a filter without a check valve?
Beginning to sludge? I suppose that could cause low pressure at startup.....
Just floating out some WAGs...
Old Aug 25, 2006 | 01:23 AM
gotitbad's Avatar
gotitbad
Oil level is good and changed way more often than needed. The noise goes away in one or two seconds. Its just alot of noise and sounds like a POS when someones walking buy.
What is a check valve oil filter? I just use the 10 dollar fram double guard and mobil one 5w30 ???
Old Aug 25, 2006 | 02:04 AM
arrowman's Avatar
arrowman
The check valve is basically a little flapper in the filter that keeps oil from syphoning back down to the pan, leaving the oil filter (and possibly upper engine pathways) dry during startup. Don't know that it would help much, considering the filter placement in an 03, but who knows? Can't hurt.... I thought FRAM PH16's had them...(which is what you're using in the Double Guard...)
Maybe you have a bum oil pump or a slighltly clogged pickup screen/tube? Again, a WAG.
The only other thing I can think of, since you mention you bought it used, is that the previous owner mistreated it in some way... neglecting maintainence or driving it like he stole it..... or both!
Old Aug 25, 2006 | 08:25 PM
speeddemon145
my 04 has always ticked for a few seconds at start up only after sitting over nite and I change oil every 3k like clock work and do not abuse the truck at all.
