Front Doors pinching
Old Aug 28, 2006 | 07:17 PM
DaHipaKea1313's Avatar
DaHipaKea1313
Default Front Doors pinching
Hey all
Anyone having problems with the front doors pinching the rubber seal along the A pillar running up along the front window? I know that when you push the door open it gets caught a little then springs back at you if your not careful. I saw in Four Wheeler Mag that they had the same problem with a 2002 test drive model but didn't talk about how to fix it.
Old Aug 29, 2006 | 08:25 PM
kenihemi's Avatar
kenihemi
Default RE: Front Doors pinching
There is a tsb for that for the 03's & 04's.
http://dodgeram.info/tsb/2005/23-005-05.htm
Old Aug 29, 2006 | 09:44 PM
sharx ram's Avatar
sharx ram
I had the same issue on my 05 and took it to Dodge and they had a recall on it so they replaced them for nothing, the newer design works great.
Old Aug 30, 2006 | 01:14 AM
DonG's Avatar
DonG
Mine wore through on my 04. Dealer replaced with new style seal. Door no longer rubs the seal.
Old Aug 30, 2006 | 01:18 AM
CarGuyOhio's Avatar
CarGuyOhio
Yup they are all correct, to the dealer!! Make sure to ask for the new design, do not let them put some old stock seals on it.
