diff fluid??
Old Aug 30, 2006 | 12:00 AM
hemi24s's Avatar
hemi24s
Default diff fluid??
anyone one know what is the best synthestic diff. fluid for a 2004 dodge 1500 hemi and what weight and how many quarts?? i lost my manual!
Old Aug 30, 2006 | 12:33 AM
reindeerman's Avatar
reindeerman
Default RE: diff fluid??
I bought my Ram used there was a little binding in the LSD when parking on pavement and slow turns. I serviced it with Mobile One 85-140w and used an LSD additive on top of that. The binding on asphalt went away and the LSD still performs great on my uphill (very steep) gravel drive to the farm.
The above will meet factory specs. I figure the extra additive even with the Mobile One may keep those nasty little LSD clips in place longer. Less chatter means less binding.
Oh Yeah, buy three quarts, but you won’t need the full three.
Old Aug 30, 2006 | 03:24 AM
arrowman's Avatar
arrowman
Sorry, don't remember off the top of my head, and we're in the middle of a monsoon, so I won't run out to the shed to see what I have out there...
I will say the weights are in the manual.
The biggest tip is to go to the dealer and buy the stupid little, overpriced, bottle of friction modifier.
If you don't, you'll do VERY BAD THINGS to your LSD.
Add a quart of oil, then the whole bottle of modifier, then top off with oil until you're full. (Should take just shy of 3 quarts of oil.)
The weights will vary based on whether you're 2x4, 4x4, gearing and towing options.
Old Aug 30, 2006 | 12:57 PM
osteodoc08's Avatar
osteodoc08
Diff service guide
