Headlight switch
Old Sep 6, 2006 | 02:47 AM
eatsleepdrivesc's Avatar
eatsleepdrivesc
Default RE: Headlight switch
yea man yours should be prewired up to go, it should be on the drivers side of the truck behind and left of the left fog light hole, this may help somemore you will be most interested in picture 12 as it shows where the plug is located, http://www.dealershipaccessories.com...pdfs/da381.pdf hope this helps
Old Sep 7, 2006 | 01:32 AM
vwomein's Avatar
vwomein
thank you, charles. I gotta get under there again, but now I know what I'm looking for
Old Sep 7, 2006 | 01:48 AM
eatsleepdrivesc
no problem man
Old Sep 7, 2006 | 09:51 PM
gordo24fan's Avatar
gordo24fan
I'm gonna thank all of you in advance. I just ordered mine up and will be looking for wires before parts arrive. Hopefully they are as easy to install as you've made it sound. $143 dollars is a pretty good price for the lights right?
Old Sep 7, 2006 | 11:29 PM
eatsleepdrivesc
do you know the part number?
Old Sep 8, 2006 | 12:33 AM
gordo24fan's Avatar
gordo24fan
82208102AB <---That is the number under the description on this page http://www.dodgepartsstore.com/produ...oducts_id=1114 . Not sure if thats a part number. Don't remember the site off hand (at work right now) that I got them for $139 delivered not $143. BUT>>>>>I just found the lights for $124.00 at https://www.dodgeparts.com/shopping_...acturers_id/15 . I could have saved some.
Old Sep 8, 2006 | 02:57 AM
eatsleepdrivesc
were you looking for like the factory pull out switch thats integrated into the headlight switch? because if you were that would be the wrong kit for it, it the kits you linked to are the ones that you have to put a switch in your dash, is your truck an SLT?
Old Sep 8, 2006 | 05:59 PM
gordo24fan's Avatar
gordo24fan
This is the one I got:
http://dodgechryslerparts.com/produc...c9701e772de0d7 (link is very slow)
Part number they show is:
T82208102 (different number than I found on other site)
The add says:
Fog Light Kit mounts in fascia, includes wiring, HEADLAMP SWITCH and lights.
I hope I got the right one. If not, I'll return it. If you have a link to the correct kit I would appreciate it if you'd post it.
Thanks,
Brian
Old Sep 8, 2006 | 06:51 PM
eatsleepdrivesc
Brian, that looks like its the correct one since it says headlight switch, it was just that on one of the other link it had a dash mounted switch
Old Sep 8, 2006 | 10:04 PM
gordo24fan's Avatar
gordo24fan
Yeah, I noticed the difference in numbers when I looked at the correct site today. I also just received an e-mail from the place I purchased it from telling me it is the correct one. That was a good catch on your part.
