Cruise Control Problem
Old Sep 12, 2006 | 04:22 AM
silentblinder9502's Avatar
silentblinder9502
Default Cruise Control Problem
I just installed a lowering kit. Nothing electrical was touched except I had to unplug my ABS plug on the spindle. I went to use my cruise control and it would not turn on. I tried resetting my ECm and it turned on for about 1 minute then shut right back off. Any ideas before I take it the stealership?
Old Sep 12, 2006 | 04:42 AM
silverram99's Avatar
silverram99
Default RE: Cruise Control Problem
I don't really know why that would cause the problem but if there is anyway you could hook the ABS back up, I would atleast try it. I don't have a theory on why that would cause you problems but it kinda seems possible, if it worked before you unplugged it and now it doesn't. I may be way off on this one though, so just my $.02
Old Sep 12, 2006 | 05:22 AM
silentblinder9502
Sorry, I got my words kinda mixed up.I meant I had to unplug it and and then I did plug it back up.
Old Sep 12, 2006 | 07:24 AM
mrchip04's Avatar
mrchip04
was the ignition ever turned on when the abs was unpluged?
Old Sep 12, 2006 | 03:47 PM
1baddodge's Avatar
1baddodge
I don't know if this will help but when I lowered my 04 I did a 2.5 front 5 rear drop wich actually level's the truck on the back axle you need to extend your rear sensor wires cause they will rub. That wire sits right on top of your rear axle. check it out and let me know. I do know that the sensor there handles your speedometer and sh$t like that. Try and see let me know. Hope this helps.
[IMG]local://upfiles/41359/4E7693E4A55944AFA2F6ADEC3CF9C209.jpg[/IMG]
