instrument cluster security light
Old Oct 19, 2006 | 02:59 AM
nate04ram's Avatar
nate04ram
Default instrument cluster security light
My security light doesn't flash after remotely locking doors. I doubt there is a fuse solely for this bulb, and all other lights work. If it is the bulb, how hard is it to change it? if not what else is there to do?
Old Oct 20, 2006 | 02:29 AM
cyclone429's Avatar
cyclone429
Default RE: instrument cluster security light
you don't have the factery security system. It was a option I did not order on my 06 2500. I'm not sure what the factery security system offers for the price upgrade.
Old Oct 20, 2006 | 08:21 PM
HemiLonestar's Avatar
HemiLonestar
If you try to use a non-coded key, it should flash and shut the truck off and keep flashing until a correct key is used.
Old Oct 21, 2006 | 06:21 AM
abarmby's Avatar
abarmby
If the bulb is fitted and importantly, in use by a trucks system, then it should light up on first starting up as a lamp check.
Al.
