oil question
Old Oct 21, 2006 | 08:18 PM
truckin151's Avatar
truckin151
Default oil question
Just curiouse but how many quarts does the 5.7L HEMI take? and whats the proper weight?
Old Oct 21, 2006 | 08:22 PM
kharding20's Avatar
kharding20
Default RE: oil question
7 quarts of 5-30. I think some people have run different weights of oil but 5-30 is what my book said.
Old Oct 21, 2006 | 09:43 PM
Dustin1515's Avatar
Dustin1515
if you look on the cap of the oil fill spot it says in clear writeing usually 5w 20 i would recomend synthetic only because it will preserve your engine longer
Old Oct 21, 2006 | 09:50 PM
djr04's Avatar
djr04
for the 06's 5w20, for the 03-05's 5w30. both versions of the hemi take 7 quarts. I second the synthetic, Mobil 1 synthetic is all I'll put in my engine. I would also recommend a Wix or NAPA gold oil filter, they may be a little more expensive, but they put the lower cost ones (fram) to shame.
Old Oct 22, 2006 | 12:13 AM
mazz's Avatar
mazz
Dodge changed the recommended viscosity on the '05 Hemi engine to 5W20, early in the model year. 5W30 remains the recommended viscosity for the '03 and '04 Hemi engines.
Old Oct 22, 2006 | 11:18 PM
MudSeasonVT's Avatar
MudSeasonVT
Member
so, if you use synthetic, how often do you change it? and how often do you change your filter?
Old Oct 23, 2006 | 04:47 AM
reiderr's Avatar
reiderr
If you're still under warranty, then don't go over 6kmi. The owner's manual says 3k to 6k depending upon conditions and never to exceed 6kmi. If you don't have a warranty concern and you want extended drain intervals, I'd recommend calibrating your particular engine and driving situation with UOAs. Most folks seem to find 5k to as much as 8k on the Hemi is possible with a good synthethic, oil filter, and the right driving conditions. Without the UOAs, though, you're just going by feel which can be deceiving. I'm my case, I had tried RP for 2 3k mi OCIs with okay "feel". But, the UOA turned up high copper wear on each change. Switched, back to a blend of M1 5 qts 5W20 and 2qts M1 5W30 Truck SUV, drove 5,500 miles on a summer road trip with all wear metals back to better than with 3kmi UOAs. In general, I stick within 6kmi with M1. No UOA I've ever done across the years on 3 different vehicles and most oil (mostly M1 syn) has ever showed the oil was worn out at that point. By 8k OCI, some were borderline. By 10k OCI, many were spent. Note: driving conditions really affect oil like. Cold weather, short trips are murder on oil. Warm weather long highway trips are relatively easy on oil.
Roger...
