2006 RAM SLT EMC Code Access
Old Nov 4, 2006 | 03:07 AM
1engineer's Avatar
1engineer
Default 2006 RAM SLT EMC Code Access
Had the EGR valve on my 2006 RAM SLT fail earlier this week. Did some reading here in the forum and attempted to retrieve the error code using the ignition switch method.
Didn’t work and I figured I would ask the service advisor at the dealership to demonstrate the on-off-on-off-on technique.
He advised me that the 2006 RAM SLT 5.7 ltr 2X4 EMC does not display the error codes using the on-off-on-off-on technique.
So, is there a different approach or must I resign myself to purchasing an OBDII reader some time down the road?
A read faced Eric in CA.
Old Nov 4, 2006 | 03:08 PM
dirtydodge02's Avatar
dirtydodge02
Default RE: 2006 RAM SLT EMC Code Access
Fortunately, there is another way. To do this, get in, hold down the Trip Odo. button, and turn the key to "run" but don't start it. It will run a short diagnostic and then it should display "C-Code" on the Odo. readout and then it'll start giving you the codes if there are any. There are a few guys on here that have a list of what all the codes are. Look up dodgerules86. I'm sure he'll be more than happy to help ya out.
Old Nov 4, 2006 | 11:26 PM
mazz's Avatar
mazz
ORIGINAL: dirtydodge02
That only gives you the "C" codes which are chassis related. The "P" codes are engine/transmission related, which the EGR valve would come under. For those, you need to connect to the computer port with a reader.
