2004 2500 hemi stalls Help !!!!!!!!!!!!
My wife has a 2004 2500 with the hemi that just stalls for no reason it hesitates for a second then stalls the dealer finds no codes and says since they can't reproduce the problem they say nothing is wrong with it anyone help.. very intermitant
2004 and 2005 hemi trucks have an update to the PCM for "idle flucuation". The Technical service bulletin # is 18-013-05. If they are finding no codes set and everything looks ok this is most likley the cause of the problem. If you have never had the PCM updated,
have them perform this TSB for you. They should cover it under the 8yr, 80,000 mile emissions warranty if you are out of your base warranty.
