5.7 rocker arm question
Old Nov 6, 2006 | 05:18 PM
dan0617's Avatar
dan0617
Default 5.7 rocker arm question
What is the stock rocker arm ratio? Is it possible to go up a little to get a little more valve lift, or would the valves hit the pistons. I know older Fords one could go from a 1.6 to a 1.7 and pick up some horses and torque without having a clearance or valve float problem Is this possible with the hemi? If so, would it help the power much?
Old Nov 7, 2006 | 04:21 PM
dan0617's Avatar
dan0617
Default RE: 5.7 rocker arm question
nobody played with the idea of higher ratio rockers on a stock hemi? Maybe I'll have to dig farther then.....and find a friend's hemi to try them out on before I put them on mine!! [sm=bicker.gif][sm=escape.gif]
