Old Aug 10, 2015, 03:38 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lighting Guides
Print Wikipost
headlight adjusting
Old Nov 12, 2006 | 08:28 PM
mikeysim's Avatar
mikeysim
Default headlight adjusting
Does anyone know the actual specs on how high and far your low beams are supposed to shine to adjust them properly? I have installed new projector headlights and the low beams seam to shine straight down, my fogs shine higher. If you would know the low beam specs then you might know the high beam specs i might assume! High beams are great except they shine straight ahead on the road about a 100 yards, no real side lumination. Any input or info would be great.
Old Nov 12, 2006 | 09:10 PM
HemiBuell's Avatar
HemiBuell
Default RE: headlight adjusting
Last time I did this I found the distance and height specs on my states registry website. I then used the back wall of a supermarket at night and taped off the height and measured out the distance.
