HEMI, Stacking Chips
Old Nov 18, 2006 | 11:12 PM
QuickSilver05's Avatar
QuickSilver05
Default HEMI, Stacking Chips
I know this works on diesel trucks, and I have to wonder if if might work on a HEMI. A Jet chip for example is a piggy back style unit sitting between the ECM and the harness, while a Superchips unit is a programmer. Is it possible to use something like a Jet chip and a Superchips unit at the same time?
Old Nov 19, 2006 | 02:44 AM
HemiLonestar's Avatar
HemiLonestar
Default RE: HEMI, Stacking Chips
The Superchips expressly tells you not to mix it with other chips/programmers. Dunno if it would work though.
Old Nov 19, 2006 | 12:25 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
I would think it would lean out the air/fuel and then go KABOOM! That's what I think.
Old Nov 19, 2006 | 04:05 PM
QuickSilver05
Well they both have timing adjustments built in to their programs, so that would probably be a problem, uless you could use the superchips just for adjusting shift points and what not, but I dunno how the superchip works exactly as I have never had one.
