pcm reset and superchips
Old Nov 23, 2006 | 03:37 AM
djr04's Avatar
djr04
Default pcm reset and superchips
I want to reset my pcm now that my truck is broken in and I drive it a lot harder. Do I need to reset to stock on the superchips, or will the pcm reset just reset the learning parameters?
Old Nov 23, 2006 | 02:39 PM
cupcake's Avatar
cupcake
Default RE: pcm reset and superchips
I don't know what you're asking in your question. But from my experince the computer doesn't adjust diffrently with mods, also the super chip is not able to be tuned on a dyno. So if what I think your asking is if you got an exhaust and reloaded stock than put the chip in it would NOT notice the exhaust and make changes.
Old Nov 27, 2006 | 04:12 PM
SUPERCHIP TUNER's Avatar
SUPERCHIP TUNER
You could just reinstall the same program that you were using and the ECU will reset.
Old Nov 27, 2006 | 04:37 PM
AIR RAM's Avatar
AIR RAM
Since your Fual adaptives are constantly adapting to the engines needs when you add a mod these needs change. Now over time your adaptives WILL adapt on their own but you can help them adapt quicker by doing a PCM reset. You do NOT need to remove your SUPERCHIPS program to reset your PCM... the SUPERCHIPS is NOW the software... all your resetting is the adaptives. So YES you should reset your PCM after adding a mod... by doing so your PCM will adapt quicker to a mod.
SPEED SAFE, AIR RAM
