Dent Puller??
Old Dec 11, 2006 | 11:18 PM
raidermike67's Avatar
raidermike67
Default Dent Puller??
Anyone ever use one of those dent puller things they advertise on this site? Uses glue and you screw it on and pop out the dent?
I clipped my rear door handle on the side of the garage door backing out a while back, popped the door handle and left a very slight indention around the handle area....it's a pretty slight indention, not noticable at first glance but want to get it fixed.
Any suggestions?
Old Dec 12, 2006 | 04:04 AM
hemiyellow's Avatar
hemiyellow
DC Insider
Default RE: Dent Puller??
if it's the same as that Ding King they use to advertise on tv, i wouldnt buy it. I bought one of those things for my other truck to try and pull some dents and it never did work for me but maybe you will have better luck with it. you can buy one of them ding king's at advance auto or autozone, someplace like that for like $20
worse comes to worse, could always pull off the int door panel and see what you can do from the inside [sm=confused06.gif]
Old Dec 12, 2006 | 04:41 AM
motorider228's Avatar
motorider228
i was with my neighbor the other night and he was using one on his mustang after his girlfriend got pissed off and punched his car. The dent didn't even budge. Those things don't work. Take it to a dent shop, it's cheap and done right.
Old Dec 12, 2006 | 11:26 AM
Uncle Hemi's Avatar
Uncle Hemi
I used the Ding King on a dent (about the size of a quarter) on my motorcycle gas tank. It popped it right out. The metal on my tank was thin, not nearly as thick as the metal on your door.
Good Luck.
Old Dec 12, 2006 | 08:42 PM
raidermike67
OK, well I'll probably pass on the dent king and go to a shop. Thanks for the info.
