Weird heater problem
Old Dec 15, 2006 | 02:25 AM
ssrdo's Avatar
ssrdo
Default Weird heater problem
On my 03 ram when I first turn the heater on it blows hot for a few seconds but then it blows cold. Does anyone know what could be the cause of this? Any help is appreciated.
Old Dec 15, 2006 | 03:40 AM
AIR RAM's Avatar
AIR RAM
Default RE: Weird heater problem
check your coolant level... then top it off! It sounds like your just low on coolant.
SPEED SAFE, AIR RAM
Old Dec 15, 2006 | 07:45 PM
ssrdo's Avatar
ssrdo
checked coolant level and it is good, any other ideas?
Old Dec 19, 2006 | 09:40 PM
jadigaba's Avatar
jadigaba
Heater core plugged maybe??
Old Dec 19, 2006 | 11:14 PM
reiderr's Avatar
reiderr
How about a blend-door malfunction! If the stepper motor or heater temperature control switch malfunction, the door that covers the heater core might only open for a short time and then close. When clsoed, no heat. Just a thought. There are dianostic procedures in the online version of the service manual. I've seen the 05 manual and suspect that the heater mechanism is no different for the 03s.
Roger...
Old Dec 25, 2006 | 05:34 PM
ssrdo's Avatar
ssrdo
Ok I had the core flushed didnt help the driver side but I am getting heat out of the passenger side vents now. Any other ideas guys??????
Old Jan 2, 2007 | 06:47 PM
beatloaf's Avatar
beatloaf
I'm having a similar problem on my 03. It will blow hot when I'm moving or the RPM's are up, butwhen I sit at a stop sign/light it starts to blow cold. This only happens when it's warming up, after a while it's fine.
