WIRE PRINTS FOG LIGHTS
Old Dec 15, 2006 | 02:53 PM
edreeve75's Avatar
edreeve75
Default WIRE PRINTS FOG LIGHTS
IF SOME HAS ACCESS TO THE WIRING DIAGRAMS FOR 02 TO 06 TRUCKS I CAN LOOK INTO TRYING TO POST THE FOG LIGHT HIGH BEAM FIXES. I STARTED LOOKING INTO THIS IN THE ANY BRIGHT IDEAS TREAD LETS ALL GET THIS FIGURED OUT I DON'T WANT TO PAY $250.00 FOR THE BRITE BOX SET UP IF I DONT HAVE TO THANKS FOR ANY HELP IN ADVANCE
Old Dec 15, 2006 | 05:15 PM
toxdoc's Avatar
toxdoc
Default RE: WIRE PRINTS FOG LIGHTS
Check out the old threads from 4/27/2005 and you'll find pics and instructions; also there is an update which appeared sometime later that suggested using the switched pin on the parking light relay instead of the constant 'hot' pin for your connection. This keeps you from having a constant hot wire from snaking across your fuse box. From the early responses of many that have made the modification, both types of connections seem to be very successful***
Old Dec 15, 2006 | 05:24 PM
toxdoc's Avatar
toxdoc
Also check out threads from 9/17/2006 submitted by schnydz; this gives a better description of the low voltage connection with pics of the pin connections
Old Dec 16, 2006 | 11:01 AM
edreeve75's Avatar
edreeve75
thanks toxdoc will do
Old Dec 16, 2006 | 04:41 PM
squirtbottle09's Avatar
squirtbottle09
The 06 wireing is differnt from the 02-05. The fogs are controlled by the computer, not relays.
