Ground Effects with Exhaust cut-out
Old Dec 18, 2006 | 11:51 PM
silverblue1989's Avatar
silverblue1989
Default Ground Effects with Exhaust cut-out
I have an 04 QC with factory ground effects like the Daytona and Rumble Bee. I have the factory exhaust cut-out on the right side and was wondering if any company made a similar panel for the left side so I can run dual exhaust. I really do not want to cut the original rear panel for tailpipe clearance. Does Someone make a solid panel for the right side so I can run the exhaust straight out the rear?
Old Dec 19, 2006 | 12:08 AM
vipersforsale's Avatar
vipersforsale
Default RE: Ground Effects with Exhaust cut-out
those are factory ground effects so no you wont find a matching drivers side panel or a right side panel with no cutout. You could just run the duals out the right side...
Old Dec 19, 2006 | 01:56 AM
Veibz's Avatar
Veibz
I to have been wondering the EXACT same thing. to split the dual exhuast on my truck. i have the ground effect as well
Old Dec 19, 2006 | 04:17 AM
shoedork's Avatar
shoedork
This sitefrom what i found does a really good job at reproducing the factory exhaust cut-out rear ground effect. If I recall they are a bit on the pricey side but all their products are completely custom made so here ya go I hope this helps.
http://www.hambekcustoms.com/products.php
Old Dec 19, 2006 | 04:24 PM
vipersforsale
I went to that site and lo and behold they do have them for you, the only difference is that the OEM effectsare made out of plastic and those aftermarket pieces are fiberglass... very interesting 6-pack hood they have too.
