differential fluid change
Old Dec 21, 2006 | 04:14 PM
tnt1036's Avatar
tnt1036
Default differential fluid change
My dealer told me that I should have my front and rear differential fluid changed at 12,000 miles. He said that it was strongly recommended by Dodge. I didn't have it done because I thought it was a money making ploy on their part. What are your thoughts? If you are not using 4 wheel drive, is your front diffential even turning?
2004 Dodge Hemi Ram 1500 SLT Quad Cab 8 foot bed.
Old Dec 21, 2006 | 06:51 PM
79LRT's Avatar
79LRT
Default RE: differential fluid change
Yes if you have a 1500 its turning , But the maintenence schedual says 15,000 miles for Diff fluid changes
Old Dec 21, 2006 | 07:48 PM
2ManyToys's Avatar
2ManyToys
The 15,000 is if you are in Schedule B maintenance. If you are in Schedule A maintenance it isn't until after 100,000+ miles that you change the oil in either the front or rear differentials. I think it might be a waste to even change it before 50,000 miles.
Old Dec 21, 2006 | 08:29 PM
helopilot's Avatar
helopilot
There was a message supposedly put out by Dodge saying that you needed to change every 15,000 miles regardless. It is a very good idea to change it due to the sheer numbers of clutch retaining clips that have been coming out, causing the rearend to fail. I guess if you wanted to change it every 50,000 miles you could but that is an accident waiting to happen.
Old Dec 21, 2006 | 10:01 PM
LoFlyer's Avatar
LoFlyer
I just did my 45k change and the oil was so clean I almost put it back in, just a little fuzz on the magnet. I'll change it again at 60k because of the warranty but after that Iwon't everchange it again. It's definitely a do it yourself project if you have the time, there's a good thread on this forum givingstep by step instructions.
Old Dec 22, 2006 | 11:19 AM
motorhead426's Avatar
motorhead426
ORIGINAL: LoFlyer
...sounds like ignorance to me. Oil breaks down after time, so I change it at the service interval. Besides, its cheap insurance over having to throw down money for a axle rebuild, and new gears... assuming the pumpkin isn't damaged if something were to grenade inside.
Old Dec 22, 2006 | 11:53 AM
2ManyToys's Avatar
2ManyToys
The rearends come with synthetic in them, so the breakdown takes alot longer than regular oil. I had a dakota before my ram and I changed it twice over the 230,000 mile life of the vehicle. If you have done some modifications to your system putting more stress on everything, then yes it might be a good idea to change more frequently. Me, I will wait...
