Engine light problem
Old Dec 22, 2006 | 02:06 AM
kiddies2's Avatar
kiddies2
Default Engine light problem
Does any one know what this means? Engine light went on as soon as I hit 50000 miles on the spedometer?Is it something that just needs to b reset?
Need some help on this one please.
Old Dec 22, 2006 | 04:08 AM
Dodge Tech's Avatar
Dodge Tech
Default RE: Engine light problem
nope have it looked at there is no preset time for it to turn on.
Old Dec 23, 2006 | 02:02 AM
Wanderer's Avatar
Wanderer
The check engine light means that the trucks computer received a signal that was out of spec. The yellow light is not normally a serious internal ptoblem, usually means your running dirty. The red light is more serious and you should not drive very far. Go to AutoZone or similar vendor and have them scan the codes. They do it for free. They have the ability to reset the computor but that does not fix the problem.
My light came on the first time a month ago. The kid who cam out with the code reader was able to determine imediately that is was loss of vacume in the gas tank. Lucked out, it was a loose gas cap. Tighten the cap, cleared the code and back on the road.
Important for everyone. At any service, have your guy scan pending codes. The computers are getting that good that they will measure changes in the operation prior to throwing a code. Even if there is nothing off by much, it may effect power and mileage or predict future problem.
Old Dec 23, 2006 | 02:23 AM
kiddies2's Avatar
kiddies2
thanks for the tip I will defenately do that hopefully thats all it is, I just changed the oil a month ago with synthetic oil so Im sure its good, Ill get it checked and let you know thanks a bunch>
MERRY CHRISTMAS!
Tracy
Old Dec 23, 2006 | 01:11 PM
CarGuyOhio's Avatar
CarGuyOhio
Do not spend money on a reader. Turn you ignition on and off 3 times in a row (do not start, just on to off position). Then any codes stored in the computer will show up in the odometer display. Post your code and we can tell you what the code means.
