Bought truck, few minor probs
Old Dec 26, 2006 | 02:54 PM
GFB's Avatar
GFB
Default Bought truck, few minor probs
I recently purchased an 03 Ram 2500 Laramie. 4wd, 5.7, 67k miles............
I assume the truck has LSD but only spins one rear tire. I read about the pins breaking in the differentials. How hard is it to replace them?
HVAC is flakey. It will not change to and from heat vents/dash vents/defrost vents most of the time. Sometimes the actuator will move if I cycle the a/c on and off (weird). Is the actuator electronically controlled or vacuum?
Does anybody have the factory service manuals on digits? If not, is there a cheap supplier for service manuals?
Thanks,
ADAM
Old Dec 26, 2006 | 06:27 PM
mazz's Avatar
mazz
Default RE: Bought truck, few minor probs
I would not assume anything. You need to verify if your truck has limited slip or not before buying parts for it. Also, you sometimes need to brieflylet off the gas to allow the unit to engage properly.
HVAC is electronic, there's no vacuum involved with it. Most likely, you have the TSB related defective defrost door. This is an extremely expensive problem to fix and not for someone who has never attemped it before. Here's alink to the TSB:
http://dodgeram.info/tsb/2003/24-004-03.htm
Asfar as the service manual goes, here's a link for that as well:
http://hemitruckclub.com/03DRM.pdf
(Hope you have high speed access. It'sa whopper!)
Old Dec 27, 2006 | 12:44 AM
GFB's Avatar
GFB
The window sticker from when it was new does not state LSD. The sticker in the glove box states 3.73 and 10.5" rear. Where else would I look?
It's been a while since I had to pull the dash in a newer vehicle. No fun at all. The weird thing is that I can sometimes get the HVAC to change to the floor. Either way I guess I'll have to get it all out to see what the problem is. Cripes.
Thanks for the manual link. It should be done downloading by morning.
Old Dec 27, 2006 | 01:08 AM
todb's Avatar
todb
It is an option so should be in the option list here is a 07 window sticker anti spin diff listed in options
[/align]
2007 MODEL YEAR
RAM QUAD CAB 1500 SLT 4X4
PRICE INFORMATION
MANUFACTURER'S SUGGESTED RETAIL PRICE OF THIS MODEL INCLUDING DEALER PREPARATION
Base Price: $ 36,830
DODGE RAM 1500 SLT QUAD CAB 4X4
Exterior Color: Bright Silver Metallic Clear Coat
Interior Color: Med Slate Gray
Interior: Cloth 40/20/40 Prem Bench Seat
Engine: 5.7L Hemi Multi Displacement Engine
Transmission: 5-Spd Automatic 545RFE TransmissionSTANDARD EQUIPMENT(UNLESS REPLACED BY OPTIONAL EQUIPMENT)
98 LITRES OF FUEL NO CHARGE
FUNCTIONAL / SAFETY FEATURES
Advanced Multistage Front Air Bags**
4 Wheel Disc Rr Anti-Lock Brakes
Speed Control
Remote Keyless Entry
Sentry Key Theft Deterrent System
Tilt Steering Column
136 Amp Alternator
600 Amp Maintenance Free Battery
Elec Shift-on-the-Fly P/Time T/Case
Engine Block Heater
Non Adjustable Pedals
12V Auxiliary Power Outlet
Power Accessory Delay
Front Heavy Duty Shock Absorbers
Rear Heavy Duty Shock Absorbers
Front Stabilizer Bar
Trailer Tow w/4-Pin Connector Wiring
3.55 Axle Ratio
205MM HD Front Axle
Corporate 9.25 LD Rear Axle
INTERIOR FEATURES
Air Conditioning
4 Speakers
AM/FM Compact Disc Radio
Power Heated Mirrors, Fold-Away
Power Locks
Power Windows, Driver One-Touch
Power Rack and Pinion Steering
Passenger Assist Handle
Overhead Console w/Trip Computer
Floor Covering Carpet
YES Essentials(R) Seat Fabric
Mini Floor Console
Manual Adjust Seats
Halogen Headlamps
Instrument Cluster w/Tach
Cargo Lamp
Rear Folding Seat
PRICE INFORMATION (contd.)[/b]
Front Height Adjust Shoulder Belts
4-Spoke Steering Wheel
Rear Underseat Compartment Storage
Passenger Side Sun Visor w/Mirror
EXTERIOR FEATURES
P245/70R17 BSW All Season Tires
17X8.0 Aluminum Wheels
Full Size Spare Tire
17" Steel Spare Wheel
Rear Fixed Window[/align]
OPTIONAL EQUIPMENT
Cloth 40/20/40 Prem Bench Seat[/align]
$ 465
Power 6-Way Driver Seat[/align]
Rear 60/40 Split Folding Seat[/align]
Front Center Seat Cushion Storage[/align]
Trailer Tow Group[/align]
$ 415
750 Amp Maintenance Free Battery[/align]
Heavy Duty Engine Cooling[/align]
Hitch - Class IV Receiver[/align]
7 Pin Wiring Harness[/align]
5-Spd Automatic 545RFE Transmission[/align]
$ 1,345
Tip Start[/align]
Auxiliary Transmission Oil Cooler[/align]
3.92 Axle Ratio[/align]
$ 50
Anti-Spin Differential Rear Axle[/align]
$ 405
5.7L Hemi Multi Displacement Engine[/align]
$ 900
Rear Window Defroster[/align]
$ 215
Fog Lamps[/align]
$ 220
20X9.0 Aluminum Wheels[/align]
$ 540
P275/60R20 BSW All Season Tires[/align]
20" Steel Spare Wheel[/align]
Federal A/C Excise Tax[/align]
$ 100[/align]
DESTINATION CHARGE[/align]
$ 1,225
TOTAL PRICE:* $ 42,710
Assembly Point/Port of Entry: WARREN, MICHIGAN, U.S.A.
VIN: XXXXXXXXX 7S138976
L4-VON:1733
*EXCLUDES LICENSE FEE, PROVINCIAL AND FEDERAL SALES TAXES AND DEALER SUPPLIED OPTIONS AND ACCESSORIES.
DaimlerChrysler
Canada Inc.
CONSUMER INFORMATION
This Vehicle is Manufactured to Meet Specific Canadian
Requirements. This Vehicle is Not Manufactured For Sale Or
Registration Outside of Canada.
Financing available through Chrysler Financial Canada
Ask your dealer for the FUEL CONSUMPTION GUIDE
or call 1-800-387-2000
2007 RAM 1500 4X4 PICKUP
8 CYL., 5.7L HEMI MULTI-DISP.
5-SPEED AUTOMATIC TRANSMISSION
[/align]CITY / VILLE
16.6
17
L/100 km
mi/gal
$ 2556.00
HIGHWAY / ROUTE
11.3
25
L/100 km
mi/gal
These estimates are based on the Government of Canada's approved criteria and testing methods. The actual fuel consumption of this vehicle may vary. Refer to the Fuel Consumption Guide.
Donnes obtenues selon les critres et mthodes d'essais approuves par le Gouver-
nement du Canada. La consummation relle de carburant de ce vhicule peut varier. Consultez le Guide de consommation de carburant.
Demandez le GUIDE DE CONSOMMATION DE CARBURANT
votre concessionnaire ou composez le 1-800-387-2000.
indow sticker
